[postgis-devel] Problems installing PostGIS 2.0SVN on PostgreSQL 9.1
Sandro Santilli strk at keybit.net
Fri Nov 18 09:51:27 PST 2011
On Fri, Nov 18, 2011 at 05:46:42PM +0100, Steffen Weber wrote:
> This is what Im getting when running ldd /usr/local/pgsql/lib/postgis-2.0.so | grep geos:
> libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007ff420eac000)
> libgeos-3.2.2.so => /usr/lib/libgeos-3.2.2.so (0x00007ff420230000)
> Should I remove one of those libs?
You probably have libgeos-3.3.so in /usr/local/lib or something
because otherwise postgis would not be attempting to use new
functions exposed by that lib. Check out geos-config --version.
If confirmed, I suggest you drop the old library, which I guess
was installed by package manager.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
