[postgis-devel] Problems installing PostGIS 2.0SVN on PostgreSQL 9.1
Sandro Santilli strk at keybit.net
Fri Nov 18 11:14:41 PST 2011
On Fri, Nov 18, 2011 at 07:39:09PM +0100, Steffen Weber wrote:
> As you suggested (did I understand right?), I manually removed libgeos-3.2.2.so inĀ /usr/lib/, resulting in:
> # ldd /usr/local/pgsql/lib/postgis-2.0.so | grep geos
> # libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007fbec2c4b000)
> # libgeos-3.2.2.so => not found
I suggested to remove with package manager, not manually.
Anyway, if you like playing hacker drop /usr/lib/libgeos*
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
