[postgis-devel] Problems installing PostGIS 2.0SVN on PostgreSQL 9.1
webste2 at web.de webste2 at web.de
Fri Nov 18 11:54:12 PST 2011
Unfortunately, I didn't install libgeos-3.2.2 using a package manager, so there is no way to uninstall using a pm (at least none that I know).
Anyway, I uninstalled libgeos-3.3.1 from /usr/local/lib and reinstalled it in /usr/lib. I had to reinstall it anyway because I manually removed
libgeos-3.2.2 from /usr/lib.
After reinstalling, PostGIS picked up libgeos-3.3.1 correctly...
So it's working know...
Thanks for the hint into the right direction...
-----Ursprüngliche Nachricht-----
Von: "Sandro Santilli" <strk at keybit.net>
Gesendet: 18.11.2011 20:14:41
An: "PostGIS Development Discussion" <postgis-devel at postgis.refractions.net>
Betreff: Re: [postgis-devel] Problems installing PostGIS 2.0SVN on PostgreSQL 9.1
>On Fri, Nov 18, 2011 at 07:39:09PM +0100, Steffen Weber wrote:
>> As you suggested (did I understand right?), I manually removed libgeos-3.2.2.so in /usr/lib/, resulting in:
>> # ldd /usr/local/pgsql/lib/postgis-2.0.so | grep geos
>> # libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00007fbec2c4b000)
>> # libgeos-3.2.2.so => not found
>I suggested to remove with package manager, not manually.
>Anyway, if you like playing hacker drop /usr/lib/libgeos*
>--strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
>_______________________________________________
>postgis-devel mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
___________________________________________________________
SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
