[postgis-devel] Build ST_GeomFromGeoJSON
maplabs at light42.com maplabs at light42.com
Sat Nov 19 17:52:07 PST 2011
aha    con-FIGURES !
somewhere in config.ac (?), the libjson test could have something like
if test -d /usr/local/include/json ; then
    libjson_prefix=/usr/local
elif test -d /usr/include/json; then
    libjson_prefix=/usr
else
    libjson_prefix=""
fi
right now, you *must* add the --with-jsondir=/usr  to get the library
even with a stock package install..
things could be better!
thx for the pointer
  -Brian
On Sat, 19 Nov 2011 15:46:38 -0800, Paul Ramsey <pramsey at opengeo.org> wrote:
./autogen.sh to regenerate ./configure
> p
> On Sat, Nov 19, 2011 at 2:52 PM,  <maplabs at light42.com> wrote:
> > maybe I am missing something basic... (Debian Wheezy, Pg 9.1, postgis_trunk
> > rev 8189)
> > sudo apt-get install libjson0-dev
> > ## package shows installed  /usr/include/json/   and /usr/lib/libjson.so
> > .so.0  .so.0.0.1  .a   .la
> > make clean; ../configure ; make; sudo make install
> > createdb test2; ...
> > \df st_geomfrom*
> > ..   st_geomfromgeojson
> > select st_astext( st_geomfromgeojson( st_asgeojson( 'POINT(1 1)')));
> > ## fail ##
> > make clean
> > ./configure --with-jsondir=/usr
> > WARNING: unrecognized options: --with-jsondir
> > psql -c "drop database test2"
> > createdb test3; ...
> > ## fail
> > -Brian
> > On Thu, 17 Nov 2011 16:19:59 -0800, Paul Ramsey
> > Thanks so much Kashif. I have applied your patch and added some guards
> >> to it's possible to compile without JSON-C supoprt, and a very minimal
> >> number of regression tests (should be expanded to cover all geometry
> >> types).
> >> Yours,
> >> Paul
> >> On Mon, Nov 14, 2011 at 8:10 AM, PostGIS <trac at osgeo.org> wrote:
> >> > #376: Add ST_GeomFromGeoJSON
> >> >  Reporter:  colivier                            |       Owner:  colivier
> >> >     Type:  enhancement                         |      Status:  new
> >> >  Priority:  medium                              |   Milestone:  PostGIS
> >> > 2.0.0
> >> > Component:  postgis                             |     Version:  trunk
> >> >  Keywords:  GeoJSON import  ST_GeomFromGeoJSON  |
> >> > Comment(by kashif):
> >> >  I have attached a patch to the current svn for testing. >
> >> > Ticket URL: <http://trac.osgeo.org/postgis/ticket/376#comment:4>
> >> > PostGIS <http://trac.osgeo.org/postgis/>
> >> > The PostGIS Trac is used for bug, enhancement & task tracking, a user
> >> > and developer wiki, and a view into the subversion code repository of
> >> > PostGIS project. > _______________________________________________
> >> > postgis-devel mailing list
> >> > postgis-devel at postgis.refractions.net
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
