[postgis-devel] [PostGIS] #1300: Add "topology" to the default search_path of topology-enabled DBs
PostGIS trac at osgeo.org
Sun Nov 20 23:50:33 PST 2011
  Reporter:  strk         |       Owner:  strk
      Type:  enhancement  |      Status:  closed
  Priority:  medium       |   Milestone:  PostGIS 2.0.0
 Component:  topology     |     Version:  trunk
Resolution:  fixed        |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Done at r8197.  It should do it for both new installs and when running the
 generated topology_upgrade_20_minor.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1300#comment:1>
