[postgis-devel] [PostGIS] #1311: ST_CreateTopoGeo: T16 regress test fails on 32bit
PostGIS trac at osgeo.org
Mon Nov 21 06:23:41 PST 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  assigned
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Changes (by strk):
  * status:  new => assigned
Comment:
 The topology created on the 32 bit has these nodes:
        2 | POINT(0 3)
        3 | POINT(2.22044604925031e-15 3)
        5 | POINT(20 4)
        1 | POINT(0 0)
        4 | POINT(10 0)
 You can see nodes 2 and 3 should likely be the same point.
 Input was: GEOMETRYCOLLECTION(LINESTRING(0 0,10 0),LINESTRING(0 3,20
 4),LINESTRING(10 0,20 4))
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1311#comment:3>
