[postgis-devel] [PostGIS] #1313: jdbc: org.postgis.Point.equals() is not reflexive
PostGIS trac at osgeo.org
Mon Nov 21 07:23:15 PST 2011
 Reporter:  slava    |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 The following test fails:
 > cat test.java
 import org.postgis.Point;
 class test
     public static void main(String[] args)
                         Point p = new Point(1, 2, Double.NaN);
                         assert p.equals(p) : "Equals must be reflexive";
                         System.out.println("Ok");
 > javac -classpath postgis-2.0.0SVN.jar test.java && java -classpath
 postgis-2.0.0SVN.jar:. -ea test
 Exception in thread "main" java.lang.AssertionError: Equals must be
 reflexive
         at test.main(test.java:8)
 There is a bug in Point.equals definition: it does not work as expected if
 the point contains NaN data field, violating on of the basic equals rule:
 reflexivity.
 The practical implication of the bug is for example eclipse databingins
 going into infinite loop firing notification for such a point ending in
 StackOverflowError.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1313>
