[postgis-devel] [PostGIS] #1317: [raster] CASE expression causes ST_MapAlgebra for 2 raster to fail
PostGIS trac at osgeo.org
Mon Nov 21 11:23:21 PST 2011
 Reporter:  pracine         |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Description changed by pracine:
Old description:
> This query:
> SELECT ST_MapAlgebraExpr(ST_AddBand(ST_MakeEmptyRaster(4, 4, 0, 0, 1, 1,
> 0, 0, -1), '32BF'::text, 6, -1), 1,
> 0, 0, -1), '32BF'::text, 4, -1), 1,
>                          'CASE WHEN rast2 > 0 THEN rast1 / rast2 ELSE
> NULL END'::text,
>                          NULL::text,
>                          'UNION'::text,
>                          NULL::text,
>                          NULL::text,
>                          NULL::double precision)
> produces this error"
> ERROR:  column "rast2" does not exist
> LINE 1: SELECT (CASE WHEN $2 > 0 THEN $1 / RAST2 ELSE NULL END)::dou...
> QUERY:  SELECT (CASE WHEN $2 > 0 THEN $1 / RAST2 ELSE NULL END)::double
> precision
> ********** Error **********
> SQL state: 42703
> There seems to be a problem when parsing CASE expressions...
> I was testing ST_Union()...
New description:
 This query:
                          'CASE WHEN rast2 > 0 THEN rast1 / rast2 ELSE NULL
 END'::text,
                          NULL::text,
                          'UNION'::text,
                          NULL::text,
                          NULL::text,
 produces this error:
 precision
 SQL state: 42703
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1317#comment:1>
