[postgis-devel] ST_MapAlgebraExpr(): Raster aggregates?
Tom van Tilburg tom.van.tilburg at gmail.com
Tue Nov 22 01:09:30 PST 2011
Pierre,
Thanks a lot.
I'm going to start testing when a new build is available where UNION is
working for ST_MapalgebraEpr() .
I rewrote the previous one a little to get an understanding of the
working and it seems to be exactly what we are looking for, with an
acceptable speed.
Tom
On 21-11-2011 22:28, Pierre Racine wrote:
> Tom,
> ST_Union is.... Fixed! Thanks to Bborie.
> Just update your source, create a fresh database (or get rid of the old MapAlgebra4Union) and execute everything up to the tests at the bottom of the file. Have a visual look at the test using OpenJump or QGIS (they were written for OpenJump with the ST_Asbinary() converting the vectorization of the result.)
> Let us know about your tests.
> For those who might be interested ST_Union() is the prototype of a function aggregating overlapping rasters into a single raster. It does pretty much the same thing as the ST_Union(geometry) aggregate but for rasters. Since it is an AGGREGATE you can use GROUP BY to aggregate based on the value of a column. You have to specify how you want raster values to be aggregated. I implemented shortcuts to MAX, FIRST, LAST, COUNT, SUM, RANGE and MEAN, but you can define your own complex aggregator by defining a STATE expression, a TEMPORARY and a FINAL expression. Have a look at the specifications in
> http://trac.osgeo.org/postgis/wiki/WKTRaster/SpecificationWorking03
> And have fun!
> Pierre
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of Tom van Tilburg
>> Sent: Monday, November 21, 2011 5:05 AM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] ST_MapAlgebraExpr(): Raster aggregates?
>> Pierre,
>> Thanks a lot for pointing me out this.
>> I've looked in to the plpgsql code but I'm afraid my current knowledge (or time)
>> doesn't allow me to contribute code.
>> However, I tested the prototype of ST_Union. It appears to be rather buggy
>> (typo's). Has it ever been applied/tested?
>> (eg: 'ERROR:  parameter name "p_nodata1expr" used more than once. '
>> seems to be copy paste error.)
>> Chrs,
>>    Tom
>> On 18-11-2011 16:54, Pierre Racine wrote:
>>> I would even suggest you write a plpgsql prototype for ST_UnionToRaster()
>> based on the specifications.... ...if you have time for sure.
>>> I would be glad to add it in the plpgsql/script on the trunk. It then becomes the
>> reference for a future C implementation.
>>> Pierre
>>>> [mailto:postgis-devel- bounces at postgis.refractions.net] On Behalf Of
>>>> Pierre Racine
>>>> Sent: Friday, November 18, 2011 10:39 AM
>>>> Tom,
>>>> Look at the plpgsql prototype of ST_Union(raster) in
>>>> http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/st
>>>> _union.sql
>>>> Have a look also at the specifications of ST_UnionToRaster(geometry,
>>>> val) in
>>>> Everything is based on ST_MapAlgebraExpr(raster, raster, expr) and
>>>> should do exactly what you want.
>>>> It should be ok for producing low resolution raster as our first
>>>> implementation of ST_MapAlgebraExpr(raster, raster) process pixel by
>>>> pixel. Higher resolution will need an optimized version of
>>>> ST_MapAlgebra(raster, raster) copying large areas of raster values
>>>> when possible (it is exactly what we need for unioning two rasters
>>>> efficiently). We started to make a plpgsql prototype for this
>>>> optimized version but it is not finished
>>>> (http://trac.osgeo.org/postgis/browser/trunk/raster/scripts/plpgsql/s
>>>> t_mapalge bra_optimized.sql). I guess we will need some funding to
>>>> make it happen...
>>>> Let me know about your experiments...
>>>> Pierre
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
