[postgis-devel] ST_MapAlgebraExpr: Wrong output for Y-data with 'UNION'
Tom van Tilburg tom.van.tilburg at gmail.com
Tue Nov 22 12:23:13 PST 2011
That will be evening for me here in Amsterdam ;-)
Thanks a lot for the reminder!
Tom
On 22-11-2011 21:20, Paragon Corporation wrote:
> Tom -- in case you didn't notice -- we put out a new build this morning.
> http://www.postgis.org/download/windows/experimental.php#PostGIS_2_0_0
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Tom van
> Tilburg
> Sent: Tuesday, November 22, 2011 4:01 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] ST_MapAlgebraExpr: Wrong output for Y-data with
> 'UNION'
> Would be great to have a windows build for r8215.
> Is that possible?
> TIA,
>    Tom
> On 21-11-2011 20:20, dustymugs wrote:
>> On 11/21/2011 04:00 AM, Tom van Tilburg wrote:
>>> Hi List,
>>> Can someone confirm wether I'm doing this wrong or the
>>> ST_MapAlgebraExpr is doing it wrong:
>>> I have two overlapping rasters that I want to add to eachother. The
>>> non-overlapping parts should be included as well and therefore I use
>>> 'UNION' in the ST_MapalgebraExpr function.
>>> This is my code:
>>> WITH sub as(
>>> SELECT
>>> raster1.rast As rast1,
>>> raster2.rast As rast2,
>>> ST_MapAlgebraExpr(
>>> raster1.rast, 1,
>>> raster2.rast, 1,
>>> 'rast1 + rast2'::text, NULL::text, 'UNION'::text, 'rast2'::text,
>>> 'rast1'::text, NULL::Double precision
>>> ) As rast3
>>> FROM
>>> raster1 ,raster2
>>> SELECT
>>> ST_Ymin(St_Envelope(rast1)),
>>> ST_Ymax(St_Envelope(rast1)),
>>> ST_Ymin(St_Envelope(rast2)),
>>> ST_Ymax(St_Envelope(rast2)),
>>> ST_Ymin(St_Envelope(rast3)),
>>> ST_Ymax(St_Envelope(rast3))
>>> FROM sub
>>> Result:
>>> Rast1 Ymin/Ymax
>>> 443752.035; 456237.035;
>>> Rast2 Ymin/Ymax
>>> 446707.035; 456242.035;
>>> Union Ymin/Ymax
>>> 443747.035; 456237.035
>>> Whereas the expected output would be:
>>> Union Ymin/Ymax
>>> 443752.035;456242.035
>>> (The X-data is outputting correctly).
>>> Regards,
>>> Tom
>> Tom,
>> Can you try r8215.  I believe it has been resolved.  The calculation
>> for the upper-left corner in the UNION case was invalid.
>> -bborie
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
