[postgis-devel] [PostGIS] #1325: topology_upgrade_20_minor.sql is harmful
PostGIS trac at osgeo.org
Thu Nov 24 13:06:44 PST 2011
 Reporter:  strk      |       Owner:  robe
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 Right after sourcing topology_upgrade_20_minor.sql, my
 topology.CreateTopology() doesn't work anymore.
 See this session:
 strk=# select droptopology('tt');
 Topology 'tt' dropped
 strk=# select createtopology('tt');
 ERROR:  schema "tt" does not exist
 Sourcing topology.sql fixes things again:
 2086
 Sourcing topology_upgrade_20_minor.sql breaks again as in the first
 example.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1325>
