[postgis-devel] Caching Double-based Boxes
Nicklas Avén nicklas.aven at jordogskog.no
Fri Nov 25 00:17:22 PST 2011
> > There is nothing that points to the index key from the geometry? Is it
> > so. It is the same reason we can't get the extent from a table from the
> > index?
> I'd think you could, altought not easily.
interesting
> But the main reason why you don't want to do that is that you don't
> want to be _forced_ to have an index in order to process values.
> Note that Geometry values could also be literal, never touching a table.
Yes, but if the geometry is literal the extra cost of calculating the
bbox seems very very small. That calculation could in that case be done
when building a geometry from text. Then all coordinates is traversed
anyway.
If the index would be the only place where the boxes was stored/cached
it would just mean that without an index the boxes will have to be
calculated each time.
If this would be possible I will vote for that in PostGIS 3 :-)
/Nicklas
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
