[postgis-devel] Boxes cache and type (was: Caching Double-based Boxes)
Sandro Santilli strk at keybit.net
Fri Nov 25 02:26:55 PST 2011
On Fri, Nov 25, 2011 at 10:38:47AM +0100, Nicklas Avén wrote:
> In my example I posted in last post, the difference is 0.3 meters! It is
> no microunits we are talking about.
What's the extent of your dataset for 0.3 meters to be so important ?
What projection ?
> The result is also that the ordering is wrong. You don't get the nearest
> point when you expect it.
Is 0.3 meters important when looking for nearest point ?
What's the use case ? Find closest glasses to a bottle on
the table in an appartment of a City ?
> I think it is more a question of being aware of it and informing that
> PostGIS knn queries might give the wrong answer even if Postgresql knn
> will give the right answer on the same dataset, just like the much
> slower st_distance way of doing it.
A NOTE in the manual would be enough to me.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
