[postgis-devel] Caching Double-based Boxes
Paul Ramsey pramsey at opengeo.org
Sat Nov 26 13:05:42 PST 2011
Thanks Brian,
Just taking the three results for each branch and averaging them and
comparing seems to show at least a 10% or maybe higher slowdown with
the double boxes.
P.
On Sat, Nov 26, 2011 at 12:44 PM,  <maplabs at light42.com> wrote:
> Hi All-
>   I have devised a second set of tests, based on the first run and some
> suggestions. There are three sets of results for each of the source builds,
> float bbox and double bbox. The condensed records are here:
>     http://download.osgeo.org/postgis/postgis_dbl_boxes_test_results22.csv
> Notes:
> * there is one test result in one run that was lost..
> * I have not analyzed these numbers.. I expect people will want to do that
> for themselves. Barring an undiscovered problem in the setup, there are very
> large differences in run times
> for the double-boxes branch, but almost entirely consistant run times for
> the float-trunk
> branch.
> * The third run in each case was after a database restart, in order, from
> top to bottom. The isolated numbers in the columns are 'cold' bbox hits..
> much much larger than
> running them a second time, so I noted them as an aside
> best regards from San Francisco, California
> Brian Hamlin
> GeoCal
> OSGeo California Chapter
> 415-717-4462 cell
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
