[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with ApplyRasterConstraints and expand # of constraints on raster columns
PostGIS trac at osgeo.org
Wed Nov 30 02:59:19 PST 2011
raster columns
 Reporter:  robe            |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by mloskot):
 Replying to [comment:23 dustymugs]:
 > Instead of having the column "out_db", the column should be renamed to
 "all_in_db"
 Is it possible to have a raster partially "in_db" and partially "out_db".
 If it is not possible, "all_" prefix is superfluous.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1319#comment:27>
