[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with ApplyRasterConstraints and expand # of constraints on raster columns
PostGIS trac at osgeo.org
Wed Nov 30 07:40:26 PST 2011
raster columns
 Reporter:  robe            |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 Replying to [comment:30 mloskot]:
 > Replying to [comment:28 pracine]:
 > > Replying to [comment:26 mloskot]:
 > > > Replying to [comment:22 dustymugs]:
 > > > > I believe the column "regular_blocking" should be renamed to
 "same_alignment"
 > > > > as it is an analog to ST_SameAlignment.
 > > > AFAICT from the current docs on ST_SameAlignment, the
 regular_blocking is
 > > > not the same concept.
 > > > The regular_blocking flag indicates if tiles in a table/coverage
 form a
 > > > regular rectangular grid, or not.
 > > samealignment is necessary but not sufficient. Regularlyblocked also
 needs
 > > samewidth, sameheight, hasnogaps and hasnooverlaps.
 > Indeed, ST_SameAlignment can not be used as replacement for the
 regular_blocking flag.
 Agreed. But you don't need regular_blocking anymore right? We are not
 planning to set this constraint, right Bborie?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1319#comment:31>
