[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with ApplyRasterConstraints and expand # of constraints on raster columns
PostGIS trac at osgeo.org
Wed Nov 30 09:52:36 PST 2011
raster columns
 Reporter:  robe            |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 > Agreed. But you don't need regular_blocking anymore right? We are not
 planning to set this constraint, right Bborie?
 I don't really see an overt need for regular_blocking unless you're
 interested in the "perfect" condition of a table with no overlaps and no
 gaps.  I know all my raster tables would fail this constraint as I put a
 year's worth or daily rasters into one table so for the whole table, there
 definitely would be overlap.
 Having same alignment be a constraint is desirable because users don't
 need to be concerned of resampling a raster before conducting a 2-raster
 operation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1319#comment:32>
