[postgis-devel] [PostGIS] #1336: [raster] Problem with ST_MapAlgebraExpr() or ST_AsRaster() alignment
PostGIS trac at osgeo.org
Wed Nov 30 11:08:36 PST 2011
 Reporter:  pracine         |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 I have a test raster that I display in Openjump:
 CREATE OR REPLACE FUNCTION ST_TestRaster(h integer, w integer, val float8)
     RETURNS raster AS
     DECLARE
     BEGIN
         RETURN ST_AddBand(ST_MakeEmptyRaster(h, w, 0, 0, 1, 1, 0, 0, 0),
 '32BF', val, -1);
     END;
     LANGUAGE 'plpgsql';
 SELECT ST_AsBinary((ST_PixelAsPolygons(ST_TestRaster(10, 10, 2))).geom);
 Then I have a simple overlapping geometry:
 SELECT ST_AsBinary(ST_Buffer(ST_MakePoint(8, 5), 4));
 If I convert it to a raster aligned on the first raster I get:
 SELECT ST_AsBinary((gv).geom), (gv).val
 FROM ST_PixelAsPolygons(ST_AsRaster(ST_Buffer(ST_MakePoint(8, 5), 4),
                                     ST_TestRaster(10, 10, 2),
                                     ST_BandPixelType(ST_TestRaster(10, 10,
 2), 1),
                                     1,
                                     -10
                         ) gv
 The two rasters are well aligned. However if I try:
 SELECT ST_MapAlgebraExpr(ST_TestRaster(10, 10, 2), 1,
 10, 2), 1),
                                      1,
                                      -10
                                     ), 1,
                          'rast1')
 I get "NOTICE:  The two rasters provided do not have the same alignment.
 Returning NULL"...
 If I just replace the rasterized geometry with the original raster like
 this:
                          'rast1')
 there is no problem...
 I am trying to implement ST_Clip()...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1336>
