[postgis-devel] [PostGIS] #1319: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with AddRasterConstraints and expand # of constraints on raster columns (was: [raster] Make raster_columns a constraint-based view, replace AddRasterColumn with ApplyRasterConstraints and expand # of constraints on raster columns)
PostGIS trac at osgeo.org
Wed Nov 30 19:00:13 PST 2011
raster columns
 Reporter:  robe            |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 Instead of ApplyRasterConstraints, use AddRasterConstraints as it is
 phonetically similar to the true SQL of "ALTER TABLE ADD CONSTRAINT".  For
 dropping constraints, use DropRasterConstraints (ALTER TABLE DROP
 CONSTRAINT).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1319#comment:40>
