[postgis-devel] [PostGIS] #1213: [raster] RT_Intersects test fails
PostGIS trac at osgeo.org
Sun Oct 2 07:19:59 PDT 2011
 Reporter:  strk            |       Owner:  dustymugs
     Type:  defect          |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Changes (by dustymugs):
  * owner:  pracine => dustymugs
  * status:  new => assigned
Comment:
 Can you run the following query?
 SELECT ST_Intersects(
         ST_AddBand(
                 ST_MakeEmptyRaster(2, 2, -1, -1, 1, 1, 0, 0, 0),
                 1, '8BUI', 1, 0
         ST_MakePoint(0, 0)
 , 1);
 The result should be TRUE.  If it is FALSE, is it possible to get the
 output from a debug build of PostGIS?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1213#comment:13>
