[postgis-devel] [PostGIS] #1222: After the switch to SRID=0 topology tests fail
PostGIS trac at osgeo.org
Mon Oct 3 09:49:52 PDT 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 The problem is CreateTopology(toponame) which uses a default srid of -1.
 Adding support for a "null" value in the "srid" column of
 topology.topology might help here.
 OR, accept that the "unknown" srid is officially '0' now and fix in that
 way.
 Won't fix until we agree on where to go from here.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1222#comment:1>
