[postgis-devel] Motion: vote for considering SRID <= 0 as "unknown"
Chris Hodgson chodgson at refractions.net
Tue Oct 4 10:46:50 PDT 2011
On Tue, Oct 04, 2011 at 10:20:51AM -0700, Paul Ramsey wrote:
>> For the difference between "implementation-defined" and
>> "implementation-dependent"
>> http://www.lispworks.com/documentation/HyperSpec/Body/26_glo_i.htm
>> Basically the spec is saying that 0 is the only "special value"
>> allowed, and we can say what its specialness is.
I actually interpret it as saying that zero MUST have a special meaning,
which is defined by the implementation. Other values MAY have special
meanings. So that would allow us to get away with <= 0 as "special" ==
unknown.
Strk I don't think you can separate these issues, they are
interdependent. The issue is standards compliance vs. legacy
compatibility, and we can satisfy both to varying degrees if we consider
all of the alternatives in concert. That said..
It seems to me that if we want to switch to zero, allowing <= 0 as
unknown will allow for -1 inputs. I'm not sure that anyone really checks
for -1 outputs? Really, this gives us the best backward compatibility,
and provides a simple change for external applications that will also
support backward compatibility (for users who didn't make custom SRIDs
with negative values, and I'm ok with that). We could also use this to
provide a migration period, whereby we could actually switch to
returning 0 instead of -1 at some point in the future, after we've given
client apps time to make the change to supporting <=0.
So I'll +1 this.
Chris
