[postgis-devel] [PostGIS] #1213: [raster] RT_Intersects test fails
PostGIS trac at osgeo.org
Wed Oct 5 04:32:54 PDT 2011
  Reporter:  strk            |       Owner:  dustymugs
      Type:  defect          |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Finally fixed. Tested with r7948 of postgis and !r23167 of gdal on the
 32bit system.
 It took a while as I had to remove an old copy of GDAL left in the system
 and wasn't that easy to correctly build GDAL to have the NumPy support,
 but I think this bug can be fixed now.
 Next time we'll have better gdal versioning info :)
 Thanks!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1213#comment:20>
