[postgis-devel] Motion: vote for considering SRID <= 0 as "unknown"
Sandro Santilli strk at keybit.net
Thu Oct 6 02:43:30 PDT 2011
On Wed, Oct 05, 2011 at 11:14:35AM -0700, Paul Ramsey wrote:
> +1 for "srid <= 0 implies unknown"
Great. 4/5 +1s. Mark still missing.
Meanwhile my patch is being tested and just as soon as I tried approaching
ST_Srid I hit the _Best_SRID issue. That function uses a negative SRID
to signal something to the ST_Transform function. Maybe it has to do
with the proj4 cache, I dunno.
Paul: could you take a look at that to make sure not to rely on any
non-unknown negative srid at the SQL level ?
To be clearer, this is the problem at the SQL level:
=# SELECT ST_Intersection(ST_GeographyFromText('POINT(0 0)'), ST_GeographyFromText('POINT(0 0)'));
ERROR:  Input geometry has unknown (0) SRID
Which I belive happens due to:
=# select _ST_BestSRID('POINT(0 0)', 'POINT(0 0)');
(1 row)
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
