[postgis-devel] [PostGIS] #1230: _ST_BestSRID should not return negative SRID values
PostGIS trac at osgeo.org
Thu Oct 6 07:56:58 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by strk):
  * priority:  medium => high
  * version:  1.5.X => trunk
Comment:
 Found the hole being in libpgcommon:
 *  Given an SRID, return the proj4 text. If the integer is less than zero,
 *  and one of the "well known" projections we support
 *  (WGS84 UTM N/S, Polar Stereographic N/S), return the proj4text
 *  for those.
 static char* GetProj4String(int srid)
 The function basically supports magic numbers with constant proj4text
 strings to save lookups in spatial_ref_sys.
 I don't know what's the best way to handle this. We might always skip the
 lookup for those numbers, would it be acceptable ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1230#comment:1>
