[postgis-devel] [PostGIS] #810: Increare accuracy of area calculation
PostGIS trac at osgeo.org
Fri Oct 7 02:30:14 PDT 2011
 Reporter:  hopfgartner  |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Changes (by strk):
  * version:  1.5.X => trunk
 Sounds good to me. Would you feel like attaching an updated patch against
 trunk and make sure the regression test still passes all ? Even better if
 you could _add_ a test in the existing tickets.sql file.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/810#comment:2>
