[postgis-devel] [PostGIS] #1230: _ST_BestSRID should not return negative SRID values
PostGIS trac at osgeo.org
Fri Oct 7 08:24:34 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Finding appropriate "reserved" srid space would require some inquiring on
 postgis-users about their current max(srid), and then enforcing the max
 and the min trough a check on spatial_ref_sys.
 We'll have to account for:
  # Builtin values (those that we ship with spatial_ref_sys.sql, which may
 grow in time)
  # Custom user values
  # Reserved range (which can't be added to spatial_ref_sys)
  # Upper limit the serialization can hold (999999)
 Not sure we need to distinguish between the first two...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1230#comment:6>
