[postgis-devel] [PostGIS] #1230: _ST_BestSRID should not return negative SRID values
PostGIS trac at osgeo.org
Fri Oct 7 10:16:15 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 I've a patch ready to commit. The patch:
  1. Writes a set of defines in libpgcommon/lwgeom_transform.h for the
 reserved SRID values
  1. Uses the macros from _BestSRID
  1. Uses the macros from ST_Transform
 There were tests in tickets.sql for the correct functioning of UTM zones
 (thanks robe) so that part is tested. I noticed _BestSRID _never_ returns
 the Polar Stereographic projections.
 The patch is attached here, if you want to review.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1230#comment:9>
