[postgis-devel] [PostGIS] #1232: Exception when calling isValid on multilinestring with only 1 point
PostGIS trac at osgeo.org
Sat Oct 8 05:58:30 PDT 2011
 Reporter:  hopfgartner  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
Comment(by hopfgartner):
 I've forgot the software version:
 "POSTGIS="1.5.3" GEOS="3.3.1-CAPI-1.7.1" PROJ="Rel. 4.7.1, 23 September
 2009" LIBXML="2.6.26" USE_STATS (procs from 1.5 r5385 need upgrade)"
 The data was probably imported by shp2pgsql and originates from some
 proprietary system, probably ESRI.
 Regards,
 Peter
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1232#comment:1>
