[postgis-devel] [PostGIS] #1185: Need DropTopoGeometryTable function
PostGIS trac at osgeo.org
Tue Oct 11 00:27:19 PDT 2011
 Reporter:  robe         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  topology     |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Technically, a TopoGeometry is independent from the table it's attached
 You may have literal TopoGeometry values, or have them used in multiple
 Substancially a TopoGeometry is fully defined by the relation table AND
 the layer record (which specifies how to interpret the definition).
 Dropping the layer record makes indeed the TopoGeometry definition
 I agree on implementing DropTopoGeometryTable, but I feel the need to
 somehow validate TopoGeometry object references (the topology.TopoGeometry
 object type) to catch malformations like the ones introduced by, for
 instance, saving a TopoGeometry object in a private/backup table and then
 dropping the referee using this function thus making the copied
 TopoGeometry a dangling reference.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1185#comment:1>
