[postgis-devel] [PostGIS] #1238: [raster] Resample and upperleftx , upperlefty (was: Resample and upperleftx , upperlefty)
trac at osgeo.org
Tue Oct 11 06:40:32 PDT 2011
Reporter: standa | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: ST_Resample |
Comment(by dustymugs):
No. That is incorrect. What versions (and revisions) of GDAL and PostGIS
are you using? I created a test transforming from 4326 to 3844
SELECT rid, (ST_Metadata(rast)).* FROM (
SELECT
1 AS rid,
ST_AddBand(
ST_MakeEmptyRaster(1, 1, 24.818115, 45.822675, 0.01, 0.01,
0, 0, 4326),
1, '8BUI', 1
) AS rast
) UNION ALL (
SELECT
2 AS rid,
ST_Transform(
ST_AddBand(
0.01, 0.01, 0, 0, 4326),
1, '8BUI', 1
3844
) AS rast
) AS foo;
If you run the SQL above, the results should be similar to:
rid;upperleftx;upperlefty;width;height;scalex;scaley;skewx;skewy;srid;numbands
1;24.818115;45.822675;1;1;0.01;0.01;0;0;4326;1
2;485990.139598202;481453.235469657;1;1;958.718116254953;-958.718116254953;0;0;3844;1
The results above are from a machine running GDAL svn-trunk !r23215 and
PostGIS svn-trunk r7964.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1238#comment:1>
