[postgis-devel] [PostGIS] #1052: Tiger Geocoder 2010 Geocode() "squishing" toward end of block
trac at osgeo.org
Thu Oct 13 09:40:30 PDT 2011
Reporter: mikepease | Owner: robe
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment(by robe):
Mike,
Wrong table. The PostGIS tiger geocoders uses the mn_addr (for street
number ranges) since that is more accurate. In theory they should be the
same but for many roads like some really complex ones they aren't and in
fact addr might have more than 2 records per tlid.
So update the corresponding records in mn_addr where the tlid is the same
as your mn_edges table corresponding to your gid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1052#comment:15>
