[postgis-devel] [PostGIS] #1052: Tiger Geocoder 2010 Geocode() "squishing" toward end of block
trac at osgeo.org
Thu Oct 13 12:29:56 PDT 2011
Reporter: mikepease | Owner: robe
Type: enhancement | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Resolution: | Keywords:
Comment(by robe):
If it's intentional as some may have suggested then not much can be done
about that. If it's just in error then would be interesting to see if we
can come up with some way of contributing corrections back. Not sure if
OpenStreetMap (OSM) does that already. I also haven't compared to see how
the accuracy between OSM and the Tiger 2010 compares. I suspect OSM may be
more accurate in some areas since the data is being constantly updated and
I know several local Govs also contribute edits to OSM directly, but they
also originally pulled some data from tiger and I'm not sure the vintage
of the pull if they have all the 2010 corrections.
anyway I am interested in making a plpgsql only geocoder patterned after
the tiger one based on OSM data if there is demand for it. That would
then cover more of the world, but yet be hopefully simple to install and
use in spatial queries with no dependency except for PostGIS and the data.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1052#comment:17>
