[postgis-devel] [PostGIS] #1227: server crash on invalid gml in st_geomfromgml
trac at osgeo.org
Fri Oct 14 04:30:54 PDT 2011
Reporter: wbloos | Owner: colivier
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: gml, invalid, crash |
Comment(by wbloos):
I'm on ubuntu 11.04, 64 bits
POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.6" USE_STATS
just reproduced it agin, but you must make sure that you remove the
question mark that is behind "<OriginalGeometry". The ticket system put a
question mark there for some reason, but it should not be there.
I can also reproduce it in Debian lenny 64 bit, with postgres 8.4 from the
backports:
POSTGIS="1.5.1" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.6.1, 21 August 2008"
LIBXML="2.6.32" USE_STATS
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1227#comment:5>
