[postgis-devel] [PostGIS] #1246: Can't make check under mingw
trac at osgeo.org
Mon Oct 17 18:49:24 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Is it just me or do others have this problem. My libraries seem to be
building fine but make check is failing when it gets to postgres tests
with this error:
/bin/sh: ./run_test: No such file or directory
make[1]: *** [check] Error 127
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1246>
