[postgis-devel] [PostGIS] #590: [raster] Two rasters version of ST_MapAlgebra
trac at osgeo.org
Fri Oct 21 07:47:41 PDT 2011
Reporter: pracine | Owner: dustymugs
Type: task | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by pracine):
Replying to [comment:12 robe]:
> I concur with Bborie. We have way too many parameters for things
already.
> Sandro was complaining about his finger getting tired what is with all
these permutations. Weren't you Sandro? We've already taken 3 keystrokes
away from him with our ST_ - do we need to torture him any more?
We have to understand here that rasters have much more internal properties
(pixeltype, nodata value, take nodata value into account or not) that we
often WANT to be able to set than geometries. There are also many ways to
set the alignment of the new raster. This is why we end up with many
variants. I see two solutions to this:
1) We should systematically use DEFAULT. Most functions should be revised
to see when variant can be removed by using DEFAULT. However from what I
understood, using DEFAULT sometimes constraint your flexibility over the
order of the parameters (DEFAULT parameters have to last).
2) We should have a "parameter order policy" respected by every functions.
We could explain this policy only once in the doc and expect every
function to follow this policy.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/590#comment:14>
