[postgis-devel] [PostGIS] #1255: ST_Union Returns NULL on valid geometries
trac at osgeo.org
Fri Oct 28 07:41:44 PDT 2011
Reporter: glock | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
Tested on
"POSTGIS="1.5.3" GEOS="3.3.1-CAPI-1.7.1" PROJ="Rel. 4.6.1, 21 August 2008"
LIBXML="2.7.8" USE_STATS (procs from 1.5 r5976 need upgrade)"
and
"POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August 2008"
LIBXML="2.7.6" USE_STATS"
This select returns NULL.
If I remove any of elements it doesn't return NULL.
If I add other element it returns NULL.
SELECT ST_Union(ARRAY[
'0103000020AD1000000100000006000000A0200889D4443C40CFB5810A85EE48401C936A44D5443C40ED1799AC84EE4840A8CF1C3AD5443C40136376AA84EE484022E010AAD4443C402D3C4DB484EE484099A0E128D4443C40E8E123BC84EE4840A0200889D4443C40CFB5810A85EE4840'::geometry,
'0103000020AD1000000100000006000000FA10AF46D1443C4057A1556A85EE4840FA10AF46D1443C4020C6974C86EE4840A07DF66DD2443C4040E2A91886EE4840D3AA0689D2443C4099CB190B86EE48400072C284D1443C40F20AB66885EE4840FA10AF46D1443C4057A1556A85EE4840'::geometry,
'0103000020AD1000000100000004000000A8CF1C3AD5443C40136376AA84EE48401C936A44D5443C40ED1799AC84EE484036762747D5443C404C5692A984EE4840A8CF1C3AD5443C40136376AA84EE4840'::geometry,
'0103000020AD1000000100000005000000D7251260CD443C40ABD8E2CF79EE4840E8875F1ECC443C40F34BDC0679EE4840B6EC5A8CCB443C4024D3AA1D79EE48405654B3BDCC443C40256648E979EE4840D7251260CD443C40ABD8E2CF79EE4840'::geometry,
'0103000020AD1000000100000005000000752AE567CE463C408199BA8A46EE4840E65C8AABCA463C40008FC6EF46EE4840E65C8AABCA463C400B10E9A147EE4840CCACEF0DCF463C40137EF92347EE4840752AE567CE463C408199BA8A46EE4840'::geometry,
'0103000020AD1000000100000005000000DD877258D0463C4064C0853847EE4840DD877258D0463C409B9B435646EE4840752AE567CE463C408199BA8A46EE4840CCACEF0DCF463C40137EF92347EE4840DD877258D0463C4064C0853847EE4840'::geometry,
'0103000020AD1000000100000005000000E03495D0BE463C40BBFCCF973CEE484009168733BF463C40FFD7F6833CEE484009168733BF463C40F589413F3CEE484004594FADBE463C40CEE4F2923CEE4840E03495D0BE463C40BBFCCF973CEE4840'::geometry,
'0103000020AD1000000100000008000000DA21591BBE463C408B435DE83BEE4840DA21591BBE463C40F3FB2ABC3CEE4840F6723054BE463C40E801C4B03CEE484004594FADBE463C40CEE4F2923CEE484009168733BF463C40F589413F3CEE484009168733BF463C40419C46CD3BEE4840ECE86E8DBE463C40FF6518D03BEE4840DA21591BBE463C408B435DE83BEE4840'::geometry,
'0103000020AD10000001000000050000002810D143C8463C405538FAAC47EE4840187D0569C6463C406A116FEB47EE4840187D0569C6463C40F0E7451248EE48402810D143C8463C40AB6C4BE047EE48402810D143C8463C405538FAAC47EE4840'::geometry,
'0103000020AD1000000100000006000000380FB7E5CB463C4025BFA87E47EE4840B0E76B96CB463C405EE3153D47EE48402810D143C8463C405538FAAC47EE48402810D143C8463C40AB6C4BE047EE4840645694B7C8463C403DE301DA47EE4840380FB7E5CB463C4025BFA87E47EE4840'::geometry,
'0103000020AD100000010000000600000011F274C9CE463C402FB5C5E446EE484050DF32A7CB463C401B453D3B47EE4840B0E76B96CB463C405EE3153D47EE4840380FB7E5CB463C4025BFA87E47EE4840CCACEF0DCF463C40137EF92347EE484011F274C9CE463C402FB5C5E446EE4840'::geometry,
'0103000020AD1000000100000005000000DD877258D0463C4046EEC4B946EE484011F274C9CE463C402FB5C5E446EE4840CCACEF0DCF463C40137EF92347EE4840DD877258D0463C4064C0853847EE4840DD877258D0463C4046EEC4B946EE4840'::geometry,
'0103000020AD1000000100000006000000DD877258D0463C4046EEC4B946EE484050DF32A7CB463C401B453D3B47EE4840B0E76B96CB463C405EE3153D47EE48404AFE841BCC463C400B6C27AB47EE4840DD877258D0463C4064C0853847EE4840DD877258D0463C4046EEC4B946EE4840'::geometry
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1255>
