[postgis-devel] [PostGIS] #1261: ST_CreateTopoGeo drops lineal input components sharing the same bounding box
trac at osgeo.org
Mon Oct 31 05:26:09 PDT 2011
box
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
I've noticed a drop in edges from input to noded input.
Most likely due to use of "UNION" vs. "UNION ALL".
Will add a testcase for it and then fix it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1261>
