[postgis-devel] [PostGIS] #1052: Tiger Geocoder 2010 Geocode() to even/odd side of street
PostGIS trac at osgeo.org
Thu Sep 1 14:46:23 PDT 2011
  Reporter:  mikepease       |       Owner:  robe
      Type:  enhancement     |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  tiger geocoder  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Changes (by robe):
  * status:  new => closed
  * version:  1.5.X => trunk
  * resolution:  => fixed
Comment:
 Done r7796-r7801
 I set the offset at 10 meters in the interpolate point function.
 Can you give it a try when you have the chance.  For the samples I did,
 seemed to put it in the correct side of the street.
 Haven investigated the shifting issue you brought up.  I thought it might
 be because Tiger data is in WGS NAD 83 rather than Google's WGS 84, but
 haven't really noticed much of a difference between the 2 at least in
 areas I've tested.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1052#comment:4>
