[postgis-devel] make doc
maplabs at light42.com maplabs at light42.com
Tue Sep 6 10:31:13 PDT 2011
Thanks to Bryce for pointing out my sleep mistake of not re-running
./configure first
however, now after a good build and install, I see..
dbb at xps-420:/home/shared/srcs_xps/postgis_trunk/doc$ make html/postgis.html
/usr/bin/xsltproc --param section.autolabel 1 --param
section.label.includes.component.label 1 --param chunk.section.depth 0
--param generate.section.toc.level 1 --param funcsynopsis.style kr
--param admon.graphics 1 --param admon.textlabel 0 --param
simplesect.in.toc 0 --param use.id.as.filename 1 --param chunk.quietly
1 --stringparam html.stylesheet style.css  \
                --output html/postgis.html \
/usr/share/xml/docbook/stylesheet/nwalsh/html/docbook.xsl \
                postgis-out.xml
ERROR: xref linking to  has no generated link text.
Link element has no content and no Endterm. Nothing to show in the link to
Brian Hamlin
GeoCal
OSGeo Califonria Chapter
415-717-4462 cell
