[postgis-devel] [PostGIS] #1181: topology.TopologySummary is broken
PostGIS trac at osgeo.org
Fri Sep 9 01:23:22 PDT 2011
  Reporter:  robe      |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  trunk
Resolution:  fixed     |    Keywords:
Comment(by strk):
 You could also drop the variable and reference rec.id directly. That's how
 I've dealt with those errors in other recent cases. 8.4 was likely fine as
 that's where I develop against. I'm glad you're enjoying the function,
 post some tiger stats ! :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1181#comment:3>
