[postgis-devel] [PostGIS] #1181: topology.TopologySummary is broken
PostGIS trac at osgeo.org
Fri Sep 9 18:43:51 PDT 2011
  Reporter:  robe      |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  topology  |     Version:  trunk
Resolution:  fixed     |    Keywords:
Comment(by robe):
 Andrea,
 Inserting directly into the tables.  The TIGER structure is very much like
 our postgis topology structure.  It has faces, nodes, edges and ids for
 them.  I figured anyone who uses (particularly if they are migrating from
 some other topology databases that uses TIGER) will want to maintain the
 same ids as TIGER does since those ids are essentially universal across
 the US so they have some significance in meaning that we would lose if I
 used our functions to load the data.
 The code I have is here in case you are interested in looking at it.
 http://trac.osgeo.org/postgis/browser/trunk/extras/tiger_geocoder/tiger_2010/topology
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1181#comment:6>
