[postgis-devel] [PostGIS] #1165: performance degradation between 1.5.3 and 2.0.0SVN
trac at osgeo.org
Tue Sep 13 07:05:36 PDT 2011
Reporter: edoardopanfili | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by darkblueb):
confirm test results
Linux tone 2.6.32-5-amd64 #1 SMP Tue Jun 14 09:42:28 UTC 2011 x86_64
GNU/Linux
AMD Opteron(tm) Processor 244
Debian 6
POSTGIS="1.5.3" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.8" USE_STATS (procs from 1.5 r5976 need upgrade)
Aggregate (cost=3539.74..3539.75 rows=1 width=0) (actual
time=116.831..116.832 rows=1 loops=1)
-> Seq Scan on gtest (cost=0.00..3535.00 rows=1895 width=0) (actual
time=0.306..110.354 rows=4063 loops=1)
Filter: ((the_geom &&
'0103000020E610000001000000090000000000000000002A40000000000000454038DB37B31D3E28403309329378F043400300000000002440000000000080434099499099C4831F403209329378F043400000000000001C40FFFFFFFFFFFF44408A499099C4831F40CCF6CD6C870F4640F8FFFFFFFFFF2340000000000080464030DB37B31D3E2840CFF6CD6C870F46400000000000002A400000000000004540'::geometry)
AND _st_intersects(the_geom,
'0103000020E610000001000000090000000000000000002A40000000000000454038DB37B31D3E28403309329378F043400300000000002440000000000080434099499099C4831F403209329378F043400000000000001C40FFFFFFFFFFFF44408A499099C4831F40CCF6CD6C870F4640F8FFFFFFFFFF2340000000000080464030DB37B31D3E2840CFF6CD6C870F46400000000000002A400000000000004540'::geometry))
Total runtime: 116.941 ms
POSTGIS="2.0.0SVN" GEOS="3.4.0dev-CAPI-1.8.0" PROJ="Rel. 4.7.1, 23
September 2009" LIBXML="2.7.8" USE_STATS
Aggregate (cost=3539.73..3539.74 rows=1 width=0) (actual
time=556.648..556.650 rows=1 loops=1)
-> Seq Scan on gtest (cost=0.00..3535.00 rows=1890 width=0) (actual
time=0.267..549.223 rows=4067 loops=1)
Total runtime: 556.732 ms
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1165#comment:15>
