[postgis-devel] [PostGIS] #1194: geometry_column wrong to establish the geometrytype in some views
PostGIS trac at osgeo.org
Wed Sep 14 14:56:25 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
 In the new postgis200,
 I notice the geometry_columns view wrong to understand the geometrytype of
 some views a bit complex.
 I have this view:
 CREATE VIEW v_unita_volumetrica AS
 SELECT
         a.id as oid,
         a.codunitavolumetrica as unita_vol,
         a.altezza_volume as alt_volume,
         a.quota_estrusione as quotestr,
         a.cod_edificio as cod_ed,
         a.cod_edificato_minore as cod_ed_min,
         c.documentation as tipoporz,
         a.codpoligono as codpoligon,
         a.codsuperficie as codsuperf,
         'SUOLO' as from,
         ST_Force_3D(b.geom) as geom
 FROM
         (( unita_volumetrica a
     LEFT OUTER JOIN suolo b ON (a.codpoligono = b.codpoligono) )
     LEFT OUTER JOIN zz_tipoporzioneunitavolumetricatype c ON
 (a.cod_tipo_porzione=c.value))
 WHERE (
         a.codsuperficie = ''
 UNION ALL
 SELECT
         a.id as oid,
         'SUP3D' as from,
 FROM
     LEFT OUTER JOIN superficie_3d b ON (a.codsuperficie = b.codsuperficie)
 WHERE (
         a.codpoligono = ''
 The geometry_view report me this having a GEOMETRY type.
 Instead it should report me a POLYGON type.
 I notice this happened on all my views with the "UNION ALL " option.
 Other views not having the UNION ALL has correctly report the
 geometrytype.
 I use postgis 2.0.0 trunk on windows.
 I don't remenber the trunk version, but is the version experimental
 released from Robe in the 4 august.
 Regards.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1194>
