[postgis-devel] [PostGIS] #1197: Newlines in shapefiles not handled correctly by shp2pgsql
PostGIS trac at osgeo.org
Fri Sep 16 00:05:53 PDT 2011
 Reporter:  dmiranda           |       Owner:  pramsey
     Type:  defect             |      Status:  new
 Priority:  high               |   Milestone:  PostGIS 2.0.0
Component:  postgis            |     Version:  trunk
 Keywords:  newline shp2pgsql  |
 Shp2pgsql will not escape the newlines on text attributes of shapefiles
 when translating to postgis. The dump will not load because the insert
 statements get split between several lines.
 Tested with postgis SVN R7856, Last Changed Date: 2011-09-15 14:43:57
 Looks like Ticket #203 reappearing on trunk.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1197>
