[postgis-devel] [PostGIS] #1199: [raster] ST_AsRaster problem with scale being < 1.
PostGIS trac at osgeo.org
Sat Sep 17 08:06:13 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 The following fails to properly burn the specified value to the generated
 raster.  If both scales are >= 1, there are no problems.  Need to see how
 gdal_rasterize utility works around the problem.
 SELECT ST_Value(ST_AsRaster(ST_MakePoint(0, 0), 0.1, 0.1), 1, 1);
 SELECT ST_Value(ST_AsRaster(ST_MakeLine(ARRAY[
         ST_MakePoint(0, 0),
         ST_MakePoint(1, 0)
 ]), 0.1, 0.1), 1, 1);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1199>
