[postgis-devel] [PostGIS] #1194: geometry_column wrong to establish the geometrytype in some views
PostGIS trac at osgeo.org
Sat Sep 17 09:54:05 PDT 2011
  Reporter:  aperi2007  |       Owner:  pramsey
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.0.0
 Component:  postgis    |     Version:  trunk
Resolution:  wontfix    |    Keywords:
Changes (by aperi2007):
  * status:  reopened => closed
  * resolution:  => wontfix
Comment:
 I definitively can close this ticket.
 I discovered that gdal give wrong result due to the size of the dataset.
 The dbf was bigger than 2GB.
 Reducing the dbf size gdal was begin to give right result.
 Is really curios that a over size on dbf could give as effect the geometry
 from polygon became linestring. :)
 However of course this is not a problem of postgis.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1194#comment:4>
