[postgis-devel] [PostGIS] #1198: ST_Union fails on some sets of polygons. Snapping works around the problem
PostGIS trac at osgeo.org
Sat Sep 17 12:31:23 PDT 2011
 Reporter:  dmiranda                                       |       Owner:  pramsey
     Type:  defect                                         |      Status:  new
 Priority:  medium                                         |   Milestone:  PostGIS 2.0.0
Component:  postgis                                        |     Version:  trunk
 Keywords:  st_union topologyexception noded intersection  |
Comment(by jgrocha):
 The same dataset, imported in PostGIS 1.5 runs fine.
 PostGIS version used:
 "1.5 USE_GEOS=1 USE_PROJ=1 USE_STATS=1"
 Commands used:
 psql geotuga < st_union_topology_exception.sql
 select gid from st_union_topology_exception where not st_isvalid(geom);
 No invalid geometries were found
 psql geotuga -c "select st_astext(st_envelope(st_union(geom))) from
 st_union_topology_exception;"
 POLYGON((-55.3756654961996 -28.9576596206607,-55.3756654961996
 -27.1734940596501,-53.0671265720575 -27.1734940596501,-53.0671265720575
 -28.9576596206607,-55.3756654961996 -28.9576596206607))
 select st_extent(geom) from st_union_topology_exception;
 "BOX(-55.3756654961996 -28.9576596206607,-53.0671265720575
 -27.1734940596501)"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1198#comment:2>
