[postgis-devel] Problems compiling ( libtool )
Chris Hodgson chodgson at refractions.net
Tue Sep 20 18:22:24 PDT 2011
I'm pretty sure the actual libtool command gets built by autogen.sh,
using "libtoolize" which needs to be on your system, and is usually
included in a package called "libtool". What OS are you using? What is
the version of libtool? (libtoolize --version)
Chris
Nathan Clay wrote:
> Strk,
> I can't seem to find, libtool in either the svn or your git repo at
> github.com <http://github.com>? Is this an oversight or ....?
> Thanks,
> Nathaniel H Clay
> On Mon, Sep 19, 2011 at 4:58 AM, Sandro Santilli <strk at keybit.net
> <mailto:strk at keybit.net>> wrote:
>     On Mon, Sep 19, 2011 at 10:55:17AM +0200, Sandro Santilli wrote:
>     > On Mon, Sep 19, 2011 at 02:34:09AM -0400, Nathaniel Hunter Clay
>     wrote:
>     > > >>/bin/sh ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall
>     > > >>-Wmissing-prototypes -I/usr/include -DPOSTGIS_GEOS_VERSION=32
>     > > >>-DPOSTGIS_PROJ_VERSION=47 -c -o stringbuffer.lo stringbuffer.c
>     > > >>eval: 1: base_compile+= gcc: not found
>     > According to that url, the libtool script in our distribution may
>     > be expecting a smarter shell than your /bin/sh.
>     Actually, I went looking at what we have in git and that one
>     is _not_ using the += construct, so your libtool must ben generated
>     on your side (or on the machine which created the distribution that
>     you used). If you are building from SVN make sure the "libtool" script
>     isn't modified and if it is try reverting it to the upstream version.
>     --strk;
>      ()   Free GIS & Flash consultant/developer
>      /\   http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
