[postgis-devel] Problems compiling ( libtool )
Nathan Clay clay.nathaniel at gmail.com
Tue Sep 20 19:19:56 PDT 2011
Chris,
I am using Ubuntu 11.10:
libtool: 2.4
gcc: 4.6
GEOS config:          /usr/bin/geos-config
  GEOS version:         3.2.2
  GDAL config:          /usr/bin/gdal-config
  GDAL version:         1.7.3
  PostgreSQL config:    /usr/bin/pg_config
  PostgreSQL version:   PostgreSQL 9.1.0
  PROJ4 version:        47
  Libxml2 config:       /usr/bin/xml2-config
  Libxml2 version:      2.7.8
  PostGIS debug level:  0
Thanks,
Nathaniel H Clay
On Tue, Sep 20, 2011 at 9:22 PM, Chris Hodgson <chodgson at refractions.net>wrote:
> I'm pretty sure the actual libtool command gets built by autogen.sh, using
> "libtoolize" which needs to be on your system, and is usually included in a
> package called "libtool". What OS are you using? What is the version of
> libtool? (libtoolize --version)
> Chris
> Nathan Clay wrote:
>> Strk,
>> I can't seem to find, libtool in either the svn or your git repo at
>> github.com <http://github.com>? Is this an oversight or ....?
>> Thanks,
>> Nathaniel H Clay
>> On Mon, Sep 19, 2011 at 4:58 AM, Sandro Santilli <strk at keybit.net<mailto:
>> strk at keybit.net>> wrote:
>>    On Mon, Sep 19, 2011 at 10:55:17AM +0200, Sandro Santilli wrote:
>>    > On Mon, Sep 19, 2011 at 02:34:09AM -0400, Nathaniel Hunter Clay
>>    wrote:
>>    > > >>/bin/sh ../libtool --mode=compile gcc -g -O2  -fPIC -DPIC  -Wall
>>    > > >>-Wmissing-prototypes -I/usr/include -DPOSTGIS_GEOS_VERSION=32
>>    > > >>-DPOSTGIS_PROJ_VERSION=47 -c -o stringbuffer.lo stringbuffer.c
>>    > > >>eval: 1: base_compile+= gcc: not found
>>    > According to that url, the libtool script in our distribution may
>>    > be expecting a smarter shell than your /bin/sh.
>>    Actually, I went looking at what we have in git and that one
>>    is _not_ using the += construct, so your libtool must ben generated
>>    on your side (or on the machine which created the distribution that
>>    you used). If you are building from SVN make sure the "libtool" script
>>    isn't modified and if it is try reverting it to the upstream version.
>>    --strk;
>>     ()   Free GIS & Flash consultant/developer
>>     /\   http://strk.keybit.net/**services.html<http://strk.keybit.net/services.html>
>> ______________________________**_________________
>> postgis-devel mailing list
>> postgis-devel at postgis.**refractions.net<postgis-devel at postgis.refractions.net>
>> http://postgis.refractions.**net/mailman/listinfo/postgis-**devel<http://postgis.refractions.net/mailman/listinfo/postgis-devel>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110920/fd707758/attachment.html>
